Larry_Sweeney Posted March 4, 2018 Share Posted March 4, 2018 1. I have been trying for hours to figure out what I'm doing wrong (or if I'm doing anything wrong) with these wall areas, which are marked "A" & "B" in the plan on the first floor. They show up as problems both on the interior and exterior areas as I try different options. This is the exterior look I'm after on both sides of the second floor room I'm also, of course wanting the correct look on the inside. It seems the more I try the worst the situation gets. I would like to have 6" walls in all the problem areas. I'm not sure if it's me or CA. I'm hoping someone can figure out a solution. If not I'll send it to tech support on Monday. 2. I also have an raised area on the 2nd floor deck that I haven't figured out what is causing the problem. Hopefully, someone might have a solution/cause for it. Thank you and good luck. CHANDLER REMODEL 5.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 4, 2018 Share Posted March 4, 2018 Here is my take DJP 1 Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 4, 2018 Author Share Posted March 4, 2018 David..............Thanks for making the video and yes I've learned a new word. After watching your video I played some more with the interior walls and was able to get the look I was after. It's not perfect, but it will do. I'm learning with working with CA not to be a perfectionist. Sometimes it's good to be one and other times-------oh well! Eric.................Invisible wall----where the heck did they come from! That was an easy fix. Especially when someone smart tells me what to do. Thank you both for your time and great advice. Have a great day Link to comment Share on other sites More sharing options...
