Library content download problem
Bob-Roraback
When in X10 with no other programs open, if I go to download additional library content and choose to open a certain library file using the open command it does not
install in X10. Instead it automatically opens Chief X9 and ends up not installing it anywhere. Any ideas? Thank you, Bob
Right-click on the file and select open with CAX10 and check mark always open with that file. When you installed X10 you probably missed specifying to associate the files with x10, if you didn't do that x9 still the default program associated with these file extensions.
You can also set that up at this point in the default program settings by selecting the file extension and assigning a default program to handle that extension.
