Default Settings Updating Existing Automatically
joedesign30
I drew my floor plan and want to change all interior doors to have no casing.  If I change the default setting of interior doors they don't update the existing doors automatically?  how can I get the existing doors to update automatically?
Thanks!
Some settings will update automatically when you change the defaults - but only if the symbols are set to use the defaults.  In some cases this is done by having (D) in the field.  In other cases there is a choice in the drop down box Use Default.  For some settings,
For Casings, it's a checkbox and that can only be set globally as DJP indicated.
