gelbuilding Posted February 20, 2018 Share Posted February 20, 2018 Trying to place draws in behind the pantry door. Actually, wire baskets draws. I know the cabinets tool have a few improvements, cannot find anywhere. I have looked in Rev-A-Shelf. Link to comment Share on other sites More sharing options...
MarkMc Posted February 20, 2018 Share Posted February 20, 2018 Rev-A-Shelf website has a zip file with 3D dog files, I believe their entire catalog. You can import from that. You'll want to look up the model number first, I keep their PDF catalog handy. Link to comment Share on other sites More sharing options...
Dermot Posted February 20, 2018 Share Posted February 20, 2018 You will need X10 if you want to insert these kinds of symbols directly into the cabinet. If you are still using X9, you can import the symbols as fixtures/furniture, manually position them and maybe block them with the cabinet to keep them together. Link to comment Share on other sites More sharing options...
MarkMc Posted February 20, 2018 Share Posted February 20, 2018 15 minutes ago, Dermot said: You will need X10 if you want to insert these kinds of symbols directly into the cabinet. If you are still using X9, you can import the symbols as fixtures/furniture, manually position them and maybe block them with the cabinet to keep them together. Several of us were making this work in X9. If using X9 you can also either... Import as a door, change the origin and place in the back of the cabinet. OR Import, place in blank plan, place the cabinet door you need in front of it. From 3D view, convert to symbol, cabinet door, change origin to just behind the door, set depth stretch plane outside the symbol. Then use as a drawer front. OR Look for post by Alaskan_Son sometime last year if you want to have the door swing open AND the basket pull out OR Upgrade as Dermot suggests (best option) Link to comment Share on other sites More sharing options...
