Hiding Window (Door) Opening Cutout When Window (Door) Layer Is Off
Chrisb222
Hi, I had this issue in Pony Walls which I made a Suggestion about that turned out to be unnecessary since that problem seems to have been addressed in X10, but this is a little different.
Many times, I want to turn off a window or door layer in a certain view, and also the cutout, but the cutout always shows.
Maybe this is different in X10 too, or am I missing something in X9 whereby the cutout can also be hidden on any floor level or wall type?
I have always just thrown a CAD mask over the cutout but thought I might be missing a setting...?
Thanks.
  • 2 years later...
35 minutes ago, Renerabbitt said:
Either make room polylines for every room including the "exterior room" or create a reference plan
32 minutes ago, solver said:
With a bit of work, you can use a reference plan without windows and doors to show the walls.
Ugh, so no easy way. Thanks for the suggestions but I think I'll make a "Suggestion." :)
