ChiefUserRichK Posted January 29, 2018 Share Posted January 29, 2018 On my plans I am seeing two labels for each window. There is only one window? How do I get rid of the "other" label. An example jpg is attached. Thank you. The windows are not mulled. Link to comment Share on other sites More sharing options...
ChiefUserRichK Posted January 29, 2018 Author Share Posted January 29, 2018 I don't believe so, the plan only shows ONE. if I delete a window from the house and then later create a window schedule for the house with new windows do I have to delete an old schedule or something? Thank you for the help. I appreciate it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 29, 2018 Share Posted January 29, 2018 There can only be one Window Schedule in the Plan File. You may have one in a CAD Detail - which is my preference because I can then send it to any desired Layout page. If there is more than one Window Schedule in the Plan then you will get an extra label. It is possible to use a second Schedule but you have to uncheck the box "Use Callout for Label" in one of them. I do this in order to create a "Window Type Legend". Link to comment Share on other sites More sharing options...
ChiefUserRichK Posted January 29, 2018 Author Share Posted January 29, 2018 Thank you. I have window labels AND schedule on in Tools/Layer Settings/Display Options. With that, I only get ONE label per window. As soon as I go to Tools/Schedules and drop in a Window Schedule two labels show up per window. Can't figure out yet how to drop the second label or find/delete the other schedule. Conundrum! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 29, 2018 Share Posted January 29, 2018 1 minute ago, ChiefUserRichK said: Thank you. I have window labels AND schedule on in Tools/Layer Settings/Display Options. With that, I only get ONE label per window. As soon as I go to Tools/Schedules and drop in a Window Schedule two labels show up per window. Can't figure out yet how to drop the second label or find/delete the other schedule. Conundrum! You could post the plan and it would probably be done in about 45 seconds. Link to comment Share on other sites More sharing options...
ChiefUserRichK Posted January 29, 2018 Author Share Posted January 29, 2018 Attached is a picture of what I am talking about. How do I "post" a plan? Thank you for your help. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 29, 2018 Share Posted January 29, 2018 It seems clear that you have a second schedule somewhere...in a CAD Detail maybe? At any rate, to alleviate guesswork and post the plan... Save the plan and CLOSE it. Click "choose files" Select your plan file and click Open Submit Reply If the plan file is too big you can do a Save As and delete unnecessary parts and pieces or you can try zipping the file and attaching that way. Link to comment Share on other sites More sharing options...
ChiefUserRichK Posted January 29, 2018 Author Share Posted January 29, 2018 The plan should be attached. Von Holten Gable_full site model 1 24 18.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 29, 2018 Share Posted January 29, 2018 2 minutes ago, ChiefUserRichK said: The plan should be attached. Von Holten Gable_full site model 1 24 18.zip You have to make sure and CLOSE the plan before you zip it. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 30, 2018 Share Posted January 30, 2018 Have you perhaps added a 2nd Schedule to another Floor by accident ? eg. The Attic level and "Lost it" , try the "All On" Layer Set ......perhaps it will show. Also it's good to have you Forum Signature Filled in like the Rest of Us , so we know which Software etc you are using etc, check mine in Blue below for a quick How To on the Sig. M. Link to comment Share on other sites More sharing options...
