Byzantine Tile Pattern
AbaloneHill
In the material dialog box I have made a material (texture) for Byzantine Tile (it is a particular shape of tile) but I can not find within Chief a pattern that matches the tile so the pattern will show up on elevations.  If I do a camera shot the material shows up.  If there is a byzantine tile patter somewhere in the *.pat files, where?  If Chief does not have a pattern then how can I make and add a patter, please?
Attached is the *.jpg texture for the materiel.
KWRC
KevinC@AbaloneHill.com
I don't think so unless one of the Tile Manufacturers in the Library has a similar tile and has done a .pat for it.
there are online Pattern Generator you could look into...
https://www.mosa.com/en-gb/services/pattern-generator
http://www.cadhatch.com/hatch-pattern-generator/4588167700
If you have Autocad too ? maybe this will do it ?
http://cadtips.cadalyst.com/node/1388?no_cache=1499103174
http://www.hatchkit.com.au/
this is a PDF of Chief Pat files someone made....
Fill Hatch Patterns Cheat Sheets.pdf
18 minutes ago, Kbird1 said:
I tested this one out ^^^ and it seems to be very easy to use and quite powerful.  I've tested some of the others in the past too but they were much more limited and much less intuitive.  If you know somebody with AutoCAD, they also have lisp routines that can can convert line work to patterns.
  • 2 weeks later...
Thanks Cheryl , I didn't have the X10 version of that Library, it now is split into two with Stone and Tile.
It is Cactus Stone> Tile > Natural Stone > Style > Kacy White Lahaina
The Tuscany Light Lahaina is also Arabesque Style...
http://www.cactustile.com/detail.aspx?id=11292
**** Unfortunately they cheated , there is no Pattern File so the Material is no good for Vector Views ,
below I changed the Colour to White and Blended it with the Texture to get these Pics.
8.thumb.JPG.48a7c76dd076fb61e7f73582a6d6105f.JPG9.thumb.JPG.c2ea01fcc3efbfc641b4cf251d5db48c.JPG
The One Above the OP Posted..... still no Pattern
0.thumb.JPG.89460fa286a696e48d6f5f5e8d9bd3fe.JPGMHD_Tile_White_Arabesque-Fancy.calibz
3 hours ago, Alaskan_Son said:
Hey, not bad Mick.  That was nice of you.
Here it is WITH the pattern.  Its not perfect but its close.
5a74060ceac31_pic1.thumb.jpg.4d835da13d906d2491b47aacaea15c55.jpg5a74060df2406_pic2.thumb.jpg.5452db978d823bcd2d26eed8b18007c4.jpg
White Arabesque Tile Fancy 2.calibz
Note that I removed the Normal Map because it wasn't quite right.
And here's the pattern file if any of you need it for anything else...
Arabesque.pat
If this helps any of you guys out enough, please consider sending a small donation my way by clicking on the Pay Pal link in my signature or visiting www.paypal.me/alaskansons
Thanks Mike.... it was the best I could to to make it "seamless" as the Pic above was not shot 100% square on to the Tile ...I don't have Photoshop for doing Bump and Normal Maps etc so I just used the Kacy White Lahiana Material and changed the Texture.
Did you buy Hatch Kit? is that how you got the Pattern file? , the free Excel Generator works well for square or rectangular tiles.
Wasn't sure I would ever use it that much so I haven't as most of the Patterns I make as Square or Rectangular , and for most Clients I use Standard Views anyway.
It amazes me that CA lets these Manufacturers do as little as possible in their Libraries , eg no Patterns or Search attributes or like the Issue with the REV-A-Shelf Catalog ... ie everything is one Material.
Yeah, not me...I use vector views, technical illustrations, and line drawings pretty heavily.  Actually, sometimes I use them very specifically for tile layouts and so the pattern can be pretty important to me.
  • 4 weeks later...
All,
I got side tracked and just got back to the forum.  Thank you again for all of your help.
My new effort is to find two files for waterfall that have disappeared originally from jaimanyi, waterfallsplashA.bmp and waterfall attempt2 copy.jpg.  I will start another line.
KWRC
650.862.5916
