TKInteriors Posted January 12, 2018 Share Posted January 12, 2018 Happy New Year! What white paint for walls gives the best result after ray tracing? I am doing a white bathroom with gloss cabinets and polished tiles. Small window and balance of light source from cans. Thank you in advance for your help. Kind regards, Tamela Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2018 Share Posted January 12, 2018 Graham , in the "Lets Raytrace Thread" suggested using 102 Arctic (White) which IIRC is actually in the Formica Catalog under Solid Elements, in the Library . I copied it to my User Library and renamed it as my "Cabinet White". Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 12, 2018 Share Posted January 12, 2018 1 minute ago, Kbird1 said: Graham , in the "Lets Raytrace Thread" suggested using 102 Arctic (White) which IIRC is actually in the Formica Catalog under Solid Elements, in the Library . I copied it to my User Library and renamed it as my "Cabinet White". So far I find it to be pretty good. I use several versions of it for my white cabinets, trim and ceiling. Just change the sheen level (roughness). For the ceiling I set it between 80 - 100% for a flat finish, trims about 30% for a pearl finish and about the same for my cabinets. For gloss cabinets I would change it to reflective(X9) and might go up as high as 70%. Link to comment Share on other sites More sharing options...
TKInteriors Posted January 12, 2018 Author Share Posted January 12, 2018 Thank you. I will give your suggestions a go at it. Appreciatively, Tamela Link to comment Share on other sites More sharing options...
