HumbleChief Posted January 11, 2018 Share Posted January 11, 2018 I sent this in to tech as I can't seem to get consistent results with some lighting in this plan when using the physically based render. NICE feature BTW but I wonder if there's something easy I'm missing? SOLVED - I had the default 8 light max limit checked in the camera. Unchecked and it works great. Thanks to Mark Mc physical rendering 1.zip Link to comment Share on other sites More sharing options...
MarkMc Posted January 11, 2018 Share Posted January 11, 2018 Can't look at plan right now, here's what I've found - it's different.... Less than 100% ambient occlusion, play with adjusting camera exposure,always use a lighting set (defaults to not doing that), avoid generated sky, never us generated sky with sun follows camera, helps to adjust the sun manually, can help to alter light lumens up drop off down and increase spread, one or two added lights that are directional with wide spread can be useful (play with height). Once you get a few that work cameras and lights can be refused and copied. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 11, 2018 Author Share Posted January 11, 2018 Thanks Mark but you are actually describing the problem. I have one and sometimes 2 of the under cabinet areas that light correctly 're-using' (copying) the light that works in to all 3 areas. One camera view will show the 2 areas lit as in the beginning of the video shows, then another camera view only shows the one area lit, but never all 3 at the same time. Were you able to view the vid or was your advice (much appreciated as always) just general PB Rendering advice? Link to comment Share on other sites More sharing options...
MarkMc Posted January 11, 2018 Share Posted January 11, 2018 Change to a light set to make sure they are on. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 11, 2018 Author Share Posted January 11, 2018 2 minutes ago, MarkMc said: Change to a light set to make sure they are on. BRILLIANT (pun intended) - I think that was it. I had the automatic 8 light max checked. Unchecked and voila. THANK YOU very much. Link to comment Share on other sites More sharing options...
