joedesign30 Posted July 25, 2014 Share Posted July 25, 2014 Former autocad user of about 8 years. Now using chief architect premier X6 (has of monday). How do i get a .dwg title block into a chief architect layout? How would i use my existing autocad block in cheif architect drawings? Link to comment Share on other sites More sharing options...
Gawdzira Posted July 25, 2014 Share Posted July 25, 2014 You can import .dwg into a chief file. For the layout I would import the .dwg into a plan file and then send that plan file to layout. This is not the best way to deal with the title block. If it was me, I would use that plan file info in layout to trace in layout to create the title block cad lines in the layout file. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted July 25, 2014 Solution Share Posted July 25, 2014 I would import the dwg into a "CAD Detail Window" so it would be isolated there for editing and then send to layout from there (I do not like to clutter up my plan view with imports unless I import the AutoCAD layer names so I can lock or turn those on and off at will. DJP Link to comment Share on other sites More sharing options...
