Dormer Flush With Exterior Wall Problem
ddestimate
I am have trouble with this design, any advice would be appreciated. I have searched the help videos and can't find anything on this application,  here is what I am trying to do.
I have attached a picture....
  • 8' walls on upper story
  • 2' step up where the dormer goes
  • dormer flush with the lower wall
  • NO ROOF plane in front of the dormer
Thanks,
rb
ps I am doing this with the  auto floating tool
If you want walls to the floor & room defs, use a normal dormer; if not, use a floating dormer. Shouldn't matter.
Size & position your dormer, then explode it, find/select/delete the "hole in roof" polyline & edit the main roof plane around the dormer cheek walls & dormer roof planes. Use "Join Roofs' tool there.
  • Downvote 1
