dskogg Posted December 7, 2017 Share Posted December 7, 2017 I was sure that i could pull markers away to not have text overlap each other, has this changed? I do not know how to do this. CA automatically did this for the 4" dimension but fails to do this for the 10" dimension. Anyone know how to do this? I called ca and they said that they did not know and to do it manually. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 7, 2017 Share Posted December 7, 2017 Maybe they thought you meant the Dimension number itself , those are movable (small square) and usually need to be , but I don't think the Marker's can be , at least not in my test plan , they can't be selected separately, but I can't get the wording to overlap like in your pic, they all move automatically like your Top of Slab Marker did M. Link to comment Share on other sites More sharing options...
JoeOster Posted December 7, 2017 Share Posted December 7, 2017 Click extension line edit square next to marker shows and can move the individual marker string up/down and left right Click on dimension to move whole story pole and each dimension Link to comment Share on other sites More sharing options...
dskogg Posted December 7, 2017 Author Share Posted December 7, 2017 1 Link to comment Share on other sites More sharing options...
mddesign Posted December 7, 2017 Share Posted December 7, 2017 Thank you David, I have played with it many times, but have never quite figured it out. I end up just doing manual dimensioning, however it doesn't always work well. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 7, 2017 Share Posted December 7, 2017 On 12/7/2017 at 9:30 PM, JoeOster said: Click extension line edit square next to marker shows and can move the individual marker string up/down and left right Click on dimension to move whole story pole and each dimension Expand Thanks Joe , when I clicked on the Extension line the edit handle only showed it could move in and out , (when hovered over) , not up or down so I didn't even try it.... M. Link to comment Share on other sites More sharing options...
