DCB123 Posted December 4, 2017 Share Posted December 4, 2017 Hey Chiefers; I am having some troubles getting my first floor 8” CMU unity walls to join properly with my Steel Sip walls above on the second floor of this structure. Without sharing the file online, proprietary reasons, I need to get someone to help me solve this issue today please? Please feel free to reach out to me if you think you can solve my issues? thx, DCB (970)987-4476 cell Email: douglasburgmann@gmail.com Link to comment Share on other sites More sharing options...
Kbird1 Posted December 4, 2017 Share Posted December 4, 2017 would be easier to see if you used the Snipping Tool , not your Phone to take pics of the screen since you can't post the plan...... might be a floor platform issue.....the gap looks to be about the same size as the Sill Plate ie 1 1/2 " Link to comment Share on other sites More sharing options...
DCB123 Posted December 4, 2017 Author Share Posted December 4, 2017 Yes, I agree there is some sort of platform issue going on here.... Your thoughts are greatly appreciated here! Call if you can help me out. Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted December 4, 2017 Share Posted December 4, 2017 Much easier to see..... and I see wall misalignment in both pics..... on the right in the 1st pic on the upper side wall and in the second pic on the left ...looking through the Arch you can see the jink in the wall lines.... Don't rely on the Alignment Tool to get it right , it definitely is not infallible..... Are the two wall types , Main layers aligned correctly? eg CMU to OSB ? ( with stucco over both?) Mick. Link to comment Share on other sites More sharing options...
javatom Posted December 4, 2017 Share Posted December 4, 2017 check the wall definitions main layers. Confirm a match to the outer layer based on dimensions. In other words - use main layer for alignment but then match the thickness of the outer layers so they align also. Link to comment Share on other sites More sharing options...
DCB123 Posted December 4, 2017 Author Share Posted December 4, 2017 I would greatly appreciate a phone call to discuss a solution here? thx, DCB (970)987-4476 cell Link to comment Share on other sites More sharing options...
DCB123 Posted December 6, 2017 Author Share Posted December 6, 2017 Finally the finished product and plans! Love it when this gets to this point. Comments please? Link to comment Share on other sites More sharing options...
javatom Posted December 6, 2017 Share Posted December 6, 2017 The last step of your stair appears to cause a choke point of clearance to walk past it. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 6, 2017 Share Posted December 6, 2017 3 hours ago, javatom said: The last step of your stair appears to cause a choke point of clearance to walk past it. I was thinking the same thing , the stairs look fairly narrow , but hard to tell where there go or what for , in those few pics... Link to comment Share on other sites More sharing options...
