ChiefuserDavidH Posted December 2, 2017 Share Posted December 2, 2017 I need 8x48 bathroom or kitchen floor tile, can anyone tell me how to make or send me the template. David => dhumphrey@kitchenkraftinc.com Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 2, 2017 Share Posted December 2, 2017 There is no "Template". You can resize any material just using the "Adjust Material" tool :https://www.chiefarchitect.com/support/article/KB-01006/customizing-a-library-material.html (which stretched to the size you want would probably look odd in camera views). Or you can find, download an existing image of a tile pattern (Ideally within a reasonable sameness to the one you want. Then import the image using the provided tools in Chief (see this help article for more data on that process: https://www.chiefarchitect.com/support/article/KB-00767/creating-a-new-material.html DJP 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted December 2, 2017 Share Posted December 2, 2017 getting the Pattern for Vector views is fairly easy , you can make a new material , set it to Tile ( for Stack bond) or Brick ( Brick Bond) and enter the sizes on the general Tab or use one of the free Pattern File Creators Online (.pat files) and use that. the hard part is finding suitable seamless textures to import to make it look good in Standard views or Raytraces, though there are a number of Websites who do free free Seamless Textures. If you can use Photoshop or similar you could make your Own too. have a look at this quick plan .....open the saved cameras ...you can save the materials to your library but they aren't great for Standard Views as I don't have the needed seamless textures. Hope CA will catch up to Modern Trends with this kind of thing soon.... 8x48 Stack Bond Tiles.plan Link to comment Share on other sites More sharing options...
cv2702 Posted December 3, 2017 Share Posted December 3, 2017 23 hours ago, DavidJPotter said: There is no "Template". You can resize any material just using the "Adjust Material" tool :https://www.chiefarchitect.com/support/article/KB-01006/customizing-a-library-material.html (which stretched to the size you want would probably look odd in camera views). Or you can find, download an existing image of a tile pattern (Ideally within a reasonable sameness to the one you want. Then import the image using the provided tools in Chief (see this help article for more data on that process: https://www.chiefarchitect.com/support/article/KB-00767/creating-a-new-material.html DJP Thanks, those articles cleared up lots of questions for me on texture handling. Link to comment Share on other sites More sharing options...
ChiefCathyKert Posted August 2, 2018 Share Posted August 2, 2018 I cannot get my tile to "brick pattern"...got the sizes correct, images correct and grout, but cannot get the brick pattern...help? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 3, 2018 Share Posted August 3, 2018 12 hours ago, ChiefCathyKert said: I cannot get my tile to "brick pattern"...got the sizes correct, images correct and grout, but cannot get the brick pattern...help? do you mean the Pattern file for Vector Views? CADHatch has a Free Excel file you can download to make many standard Pattern Files as well as some textures etc. http://www.cadhatch.com/hatch-pattern-generator/4588167700 http://www.cadhatch.com/seamless-textures/4588167680 If you mean Standard View or PBR then the Texture must be Brick Patterned (a seamless texture). M. Link to comment Share on other sites More sharing options...
