crosscutter55 Posted December 1, 2017 Share Posted December 1, 2017 I need to draw 4 x 4 post, for a deck rail attached to the outside of the deck . The standard rail will not let me increase the length of the post to the bottom of the deck joist , & keep my bottom rail 4" above the decking , is there a way to achieve this , or do i have to draw all these componets of the rail manually ? Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 1, 2017 Share Posted December 1, 2017 Manually. Size the posts in the rail the same size as the balusters and then add the manual posts. DJP Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2017 Share Posted December 1, 2017 Did you see my post in the other thread that I gave you the link for when Mick and I tried to help you with the same question ? Here is a direct link : If your design has a bottom rail this technique may work perfectly for you but without the details I asked for I am unable to test it for you as railings are very finicky. You can draw whatever you like manually but if one of the existing tool can be used it will save you a lot of time. Link to comment Share on other sites More sharing options...
