crosscutter55 Posted November 25, 2017 Share Posted November 25, 2017 I need to have deck rails with 2# 4x4 on the corners of the deck bolted to the outside of the decks box . Is there a way to customize and an existing rail to do this ?? and if so how would i begin Link to comment Share on other sites More sharing options...
Kbird1 Posted November 25, 2017 Share Posted November 25, 2017 do a search on fascia mounted railings and you should find one where I and Glenww are discussing this and he shows a way to do it and another by WhistlerBuilder i think it was who had the same question... Link to comment Share on other sites More sharing options...
Chopsaw Posted November 26, 2017 Share Posted November 26, 2017 20 hours ago, crosscutter55 said: I need to have deck rails with 2# 4x4 on the corners of the deck bolted to the outside of the decks box . Do you have a photo or cad detail with the rest of the details... Spindles and rail configuration etc. I have been working on something new that might work and is a little more automated. Each workaround seems to have limitations that you have to be aware of. I think I may have since figured out a way to complete this system if yours is anything like this : Link to comment Share on other sites More sharing options...
Kbird1 Posted November 26, 2017 Share Posted November 26, 2017 One method ...another in the full thread... Whistler Builders Thread https://chieftalk.chiefarchitect.com/topic/13653-fascia-mount-railings/#comment-116446 Link to comment Share on other sites More sharing options...
