sjalheim
Door in a railing
I've searched but the answer still fails me: when I put a door into my screened porch, it shows up the way it should... in 3d only. In 2d I just get the opening unless I click on it. Any ideas?
You'll get a much quicker and more accurate response if you post the plan file.
Its the Follow Stairs setting that's doing it.  Uncheck that and you should be good to go.  On a side note, this should probably be reported to tech support.  I'm not sure there's any good reason it should be behaving that way.
That is really strange indeed , especially as there is no stairs (yet)  but I would check your default settings for Railings as Follow Stairs should not be checked by default for every Railing , it is used for railing on Stairs only usually....
    27469
    THDesign
    THDesign
  • Similar Content
    • By blueriver
      I have a persistent problem with gaps in my porch ceilings in between the finished surface and the underside of the roof structure.  I know it has to be a setting i have wrong but i cannot figure it out! Current project is a barndominium with a gable porch.
      Thanks in advance
    • By DeckQuestions
      Is there a way to make the top rail of my deck railing rounded?
    • By Sweeney
      Hey All,
      Is there any way to include the jamb width in a door schedule? For example...
      Door Unit is a Marvin Clad Ultimate CUFD 3070 S LHIS
      Door Frame Size: 37 7/16" x 86"
      Door Jamb Size: 1 3/16"
      Door schedule shows the width as 35-1/16...**37-7/16" - (1-3/16 x 2)** and I want it to show 37-7/16
      Is there a macro I can edit to act more like the widow schedule preforms?
      Thanks is advance,
      Austin
    • By Sweeney
      Hello all,
      Is there an easy way to separate interior and exterior doors into two different schedules?
      Thank you in advance,
      Austin
    • By ChiefArchitect
      An enclosed porch can be a welcome reprieve from the blazing sun in the summer months, and provide a protected cove during cooler times.
