country Posted November 9, 2017 Share Posted November 9, 2017 I did a bunch of text Macros on my last plan using text macro management. I thought I read that this is something Perry used and it seemed to be a practical way to do some of these mundane but necessary items. Now, working on another drawing that needs these same notes, I find they are not available. Do I have to import and export these to every new plan if they are not from the same template? I thought user Macros were program, not plan specific. i can always block them on the old plan, make them symbols and put them in library folders but I really dislike using the library for notes. I have tried to use Help guidance but I don't seem to be able to comprehend. I think I hate typing as much as Perry! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 9, 2017 Share Posted November 9, 2017 Sherry, User Macros are Plan Specific. You can simply select all macros in TMM and export them. Then in other plans import the json file using TMM. I you import them into your template they will be available in all new plans. Link to comment Share on other sites More sharing options...
country Posted November 9, 2017 Author Share Posted November 9, 2017 Thank you Joe. I will do that for this job and then I will have them for a future job. I use a modified Save As system but plan on doing an entirely new template when the next version is out. Your explanation is certainly easier to follow than the Help files. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 9, 2017 Share Posted November 9, 2017 JOE IS ABSOLUTLY CORRECT, I WAS JUST TESTING HIS KNOWLEDGE Link to comment Share on other sites More sharing options...
country Posted November 9, 2017 Author Share Posted November 9, 2017 It certainly is a timesaver. Thank you for the idea Perry and Joe for passing the test! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 10, 2017 Share Posted November 10, 2017 Actually it is Joe who is the master macro man, I'm just learning. Link to comment Share on other sites More sharing options...
