Remove PLAN from Layout file
ACADuser
Hmmm, i'm not aware of a way to remove a referenced file within the referenced file dbx or as a batch. If linking the referenced file to the new file to the layout isn't what you are after, then what I do is turn on the borders and then go through each page and delete them.  For me, this happens when doing a 'save as' but then the file changes and the referenced layout is now just showing white because the plan has moved, reversed, etc.  So turning the layout borders helps to see these and then adjust or delete as needed.  If no one chimes in with a batch way to do that, would be a good suggestion.
All the best.
If you highlight the referenced plan you don't want, you can put in the current plan just as you would with a "save as".  Having 2 of the same file as the referenced one hasn't been a problem the couple times I have had to do it.  Maybe someone can tell me if this is an issue.
