dskogg Posted October 18, 2017 Share Posted October 18, 2017 This might sound like a stupid question, but is there no way of making the stringer a material other than the risers? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted October 18, 2017 Share Posted October 18, 2017 I believe they are tied together. If you select the material you want and then select the "C" painter option and then paint the item you want to be different, then if the other item also changes then they are tied together, if only the single item changes then they are independent. Link to comment Share on other sites More sharing options...
dskogg Posted October 18, 2017 Author Share Posted October 18, 2017 Thanks Eric, i wanted to show carpet on stairs and another material on stinger. Maybe i can use a carpet runner full width? Seems very odd that ca would have the stringer the same material as stairs, this is not the norm in my area? Cheers. Link to comment Share on other sites More sharing options...
yusuf-333 Posted October 19, 2017 Share Posted October 19, 2017 Here https://chieftalk.chiefarchitect.com/topic/8410-johnnys-modern-stair-tip/ Link to comment Share on other sites More sharing options...
dskogg Posted October 19, 2017 Author Share Posted October 19, 2017 Thanks for reply’s it seems like ca has some work to do on stairs. adjustible stringer thickness comes to mind as well as separate material for stringer. in my area for a standard builder house they use a stringer against wall and run carpet up the inside of stringer to the top and then a wood cap is put on top of stinger against wall to finish off. but there is about 1/2” of space between stringer and wall then a 1.5” stringer.. Link to comment Share on other sites More sharing options...
