Line Drawing
wncbw7
Yes open your layout box DBX and set the Camera View Options to Plot Lines until you are finished working with the layout file with the plan file also open.  This should drastically improve your speed and performance until you are ready to present or print.  Hoping Chief will either fix this issue or give us a quick way to switch between working mode and print/presentation/final mode with X10.
There is also the option in the DBX to Update on Demand but still slows the whole file.
38 minutes ago, wncbw7 said:
When I use line drawing rendering it wants to keep rerendering. Is there a way to tell it not to do that?
If you are talking about what happens when you pan/zoom/rotate in a 3D perspective - this is normal because the lines have to be recreated by software.  Standard Render Mode OTOH is done in Hardware by the GPU.  X9 has alleviated this a bit by switching to Standard Mode while a pan/zoom/rotate is being done - but it switches back when that's finished and then recreates the lines.
It's best while working to just use Standard Mode.  Only use the other modes when you want to prepare an "artistic" render to print.
