MarkSM
gable missing
Trying to get this gable over the entry. Im sure its a simple click of a button, but I can't figure out what how the heck to do it. Thanks in advance...
Gober 10.14.plan.zip
I'm away from my computer so I cant test this, but one of the first things I'd recommend you do is check to see if there's an attic wall in that area.  If there's not, either turn auto attic walls back on or manually draw your own.  If there IS, it may be an invisible wall...delete it and it should revert to a normal attic wall.
or mark the wall below the missing attic wall as "balloon through ceiling".
I may not have sent the updated plan, Eric. Thank you. Its updated now
Michael is correct -- rogue attic walls.
Also, several walls had their top and bottom heights manually changed, which should be avoided.
I deleted the attic level and let the program rebuild it. Also moved the dormer walls to the attic level, and rebuilt the roof.
Gober 10.14 (eric).plan
Yes Eric but wouldn't';t that wall be balloon framed in real life. hinged is not good in that situation. Maybe just in California.
That's how I would do it.
    27475
    slickrick1530
    slickrick1530
