TNBDesignOffice Posted October 13, 2017 Share Posted October 13, 2017 Hi folks we are a new design build firm just starting out in Chief. I have a Window Schedule issue that I need resolved ASAP..... Please see the attached PDF - I need W03 and W04 to be the same number. They are identical as I copied W03 to W04 location. Thank you in advance for your consideration. Jay windows.pdf Link to comment Share on other sites More sharing options...
DavidJames Posted October 13, 2017 Share Posted October 13, 2017 Can you post your plan file so we can take a look? 1 Link to comment Share on other sites More sharing options...
TNBDesignOffice Posted October 13, 2017 Author Share Posted October 13, 2017 Would just that portion of it help - ofcourse the numbers would change but I have no idea why they are different numbers. Link to comment Share on other sites More sharing options...
TNBDesignOffice Posted October 13, 2017 Author Share Posted October 13, 2017 The floor levels are different in the rooms could that be it? Anyway is there a way for them to have the same number? Thats what i really want. Link to comment Share on other sites More sharing options...
TNBDesignOffice Posted October 13, 2017 Author Share Posted October 13, 2017 OK will do thanks. Link to comment Share on other sites More sharing options...
TNBDesignOffice Posted October 13, 2017 Author Share Posted October 13, 2017 And just like that the number is the same how I want it in the small version of the plan attached....lol...wow....I even changed the floor heights to check. Window Schedule Blues.plan Link to comment Share on other sites More sharing options...
Richard_Morrison Posted October 13, 2017 Share Posted October 13, 2017 Select the schedule and click on the "Renumber Schedule" icon to see if that helps. Link to comment Share on other sites More sharing options...
Dermot Posted October 13, 2017 Share Posted October 13, 2017 Look at the schedule in your original plan to see if the info displayed for w03 and w04 is actually the same. Schedules will only group objects based on the information displayed in the schedule. If the objects have the same data for all columns displayed, then they should be grouped together. If any of the data for any column is different, then the objects won't be grouped. The only exceptions to this rule are the schedule number and if you are displaying any previews in the schedule. If all else fails, you may wish to post the original plan or contact technical support for more help. Link to comment Share on other sites More sharing options...
TNBDesignOffice Posted October 13, 2017 Author Share Posted October 13, 2017 Thank you all. Checking it out now Link to comment Share on other sites More sharing options...
TNBDesignOffice Posted October 13, 2017 Author Share Posted October 13, 2017 OK Demot that was it. I have the Room Name Column Selected and that did it. The sample did not have room names so the numbers were the same. Wow wish I could get the room names and the same number for similar window types. Oh well. Link to comment Share on other sites More sharing options...
rfantclt Posted November 17, 2017 Share Posted November 17, 2017 On 10/13/2017 at 0:48 PM, TNBDesignOffice said: The floor levels are different in the rooms could that be it? Anyway is there a way for them to have the same number? Thats what i really want. I had the same problem with different Labels being assigned to the same window type. Removed the Floor Level column from my schedule and it grouped/numbered them all by type with the same W#. My window supplier will really be happy! Thanks! Link to comment Share on other sites More sharing options...
