Sign in to follow this
GeneDavis
Change spacing of vertical web members of end wall trusses?
I want 24" but am unable to change it from 16".  Any way to do this?  Trusses are in unframed gable walls that have wall def for main (framing) layer at 24-in centers.
Thanks but that did not work.  I changed the stud spacing in the build framing dialog to 24.  Changed the attic wall's spec also.  Forced the truss rebuild.
File attached.
Storage and guest.plan
Gene, Make sure the change is made in Plan Defaults and it should work fine.
Thanks!  It was Plan Defaults that was the place.
All fixed.  Going back to award some points.
    27855
    kfilipova
    kfilipova
