raltd9245 Posted September 12, 2017 Share Posted September 12, 2017 I can't seem to generate the second floor walls. Ideas Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 12, 2017 Share Posted September 12, 2017 24 minutes ago, raltd9245 said: I can't seem to generate the second floor walls. Ideas post a .plan please Link to comment Share on other sites More sharing options...
raltd9245 Posted September 13, 2017 Author Share Posted September 13, 2017 I fixed it, my mistake Link to comment Share on other sites More sharing options...
raltd9245 Posted September 14, 2017 Author Share Posted September 14, 2017 Now I have another question. Due to owner changes I have to adjust ceiling heights floor thickness and second flr clg height. What is the easiest way to do this for an entire floor. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 14, 2017 Share Posted September 14, 2017 2 hours ago, raltd9245 said: Now I have another question. Due to owner changes I have to adjust ceiling heights floor thickness and second flr clg height. What is the easiest way to do this for an entire floor. if you built your rooms using the defaults, then you would just go in to your room defaults and change those settings and it will shift all of your rooms accordingly. If your second floor is to be different from your first, I have had luck in the past using a layer that only shows my walls and selecting all of my interior walls, then setting them to "no room definition." then you can select the entire second floor, set the parameters, and set the walls back to room definition. There may be an easier way but I don't know it at the moment. Link to comment Share on other sites More sharing options...
country Posted September 14, 2017 Share Posted September 14, 2017 Open the top floor and adjust it using the floor defaults. Work down from the top floor. If some of your rooms are not set to default, you will have to do that first. Link to comment Share on other sites More sharing options...
raltd9245 Posted September 15, 2017 Author Share Posted September 15, 2017 Thank you all Link to comment Share on other sites More sharing options...
RL-inc Posted September 16, 2017 Share Posted September 16, 2017 Great idea Rene on the no room def. I'll give that a whirl sometime Link to comment Share on other sites More sharing options...
