Auto visual union boolean hit/miss
johnny
Depends on what camera you use to view it and you have to join them, not mash them together.  Just like real life but no nails screws or glue.
7 psolids in vector perspective full overview.
Same in Elevation View
My $0.02...
Do an ACTUAL union or reshape those objects so there is no overlap.  Other than that, you are correct...it is a little hit and miss.  If perfectly aligning the objects doesn't work and if you don't want to reshape the objects I think your next best bet is one or more of the following...
  • Use one or more overlayed CAD patches or overlayed p-solids.
  • Set one or more of the objects to use the invisible line style.  This only works well for certain circumstances.
  • In conjunction with using the invisible line style, add your own lines only where necessary.  Depending on the view type this can either be done with actual CAD or with a thin 3D object.
  • Remove the extraneous lines in layout using Edit Layout Lines.
All workarounds I know, but at least its sumpthin'.
