DBearss Posted August 25, 2017 Share Posted August 25, 2017 I am working on tenant improvements for an office that wants the ends of the walls between the open offices to be glass. I used a shower door and can get the glass to go to the ceiling but we want to get rid of the little bit of wall at the end. Am assuming CA wants some framing there. Any way to accomplish a frame less glass partition? Glass wall.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2017 Share Posted August 25, 2017 Yes you can create a glass pony wall that should work fine there. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 25, 2017 Share Posted August 25, 2017 you can use a Soffit from the Cabinet's Menu , make the material 3/8 thick and Glass , Standard. Then sit it on top of your 1/2 wall. assuming I understand what you are trying to do? There is an Office Cubicle Library too ...maybe it has what your are looking for in there premade for you ? worth a look... https://3dlibrary.chiefarchitect.com/index.php?r=site/download/898&version=6 M. Link to comment Share on other sites More sharing options...
DBearss Posted August 25, 2017 Author Share Posted August 25, 2017 Ah! Super easy. Thanks. Link to comment Share on other sites More sharing options...
NGPartitions Posted 8 hours ago Share Posted 8 hours ago Hi, we can help with this. Get in touch at National Glass Partitions we can make bespoke glass partitions for any size or use. 1 Link to comment Share on other sites More sharing options...
