millerhomedesign Posted August 19, 2017 Share Posted August 19, 2017 I have searched here and also google... I am wanting a solution to make a wall follow the riser up the stairs. In other words I want from the bottom of the riser to the ceiling of bottom floor enclosed. See the picture attached, I hope you can understand it from there. The stairs go up to a landing then turn. From the landing up to second floor will be visible in the garage. So I want to create a wall that follows the riser to enclose the stairs. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 19, 2017 Share Posted August 19, 2017 Post the plan..... But I think you can do it by drawing the wall full length , then in a Elevation View shape the Wall to the desired angle , it may require messing with a soffit or wall material region to make the Drywall look right though... Try a search on HomeTalk too ...I think I posted about this over there at one point too. M. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 20, 2017 Share Posted August 20, 2017 Chief really should handle this automatically, been a request for a long time. Link to comment Share on other sites More sharing options...
millerhomedesign Posted August 21, 2017 Author Share Posted August 21, 2017 Thanks Solver. It didn't need to be perfectly finished out but I wanted it closed up. Just so when I show the client the interior view it would look somewhat correct. Link to comment Share on other sites More sharing options...
Kelly_K Posted August 23, 2017 Share Posted August 23, 2017 On 8/20/2017 at 10:26 AM, DRAWZILLA said: Chief really should handle this automatically, been a request for a long time. Yes a button to tell the wall to follow the stair stringer, horse, buck, etc. would definitely be welcomed. Link to comment Share on other sites More sharing options...
