myrtsbnye Posted June 10, 2017 Share Posted June 10, 2017 Is it possible to show windows as tilt-turn windows? I've searched here and online and haven't found anything on this topic. In elevation a tilt-turn window has an operating symbol similar casement window AND an awning window combined since the window can be opened as a casement window or an awning window (hinged at the bottom though in this case). Thanks 2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 10, 2017 Share Posted June 10, 2017 I haven't seen anything like that in Chief, You might have to make your own symbol for that. A lot of work for sure, but you can use the comment section of the window schedule to note exactly what you want, it just won't look correct in any views. Link to comment Share on other sites More sharing options...
myrtsbnye Posted June 10, 2017 Author Share Posted June 10, 2017 Thanks Perry, I will attempt making the symbol but if all else fails maybe just add cad lines to show the operation directions. Link to comment Share on other sites More sharing options...
glennw Posted June 11, 2017 Share Posted June 11, 2017 Not perfect, and a bit of overkill, but you could always copy the window in place, change it's Type, uncheck Include In Schedule..... Link to comment Share on other sites More sharing options...
aleohio Posted February 20, 2024 Share Posted February 20, 2024 I used a glass panel door, adjusting the Panel Frame Widths, to at least get the look and handle hardware correct. This lack of tilt-turn and different right/left double door sizes makes it seem as though they don’t want to sell their otherwise mostly great software outside of North America. The hate/misunderstanding/non-awareness of tilt-turn windows is quite wide spread here. One of the best North American window manufacturer does offer them, but at almost TEN TIMES the price of their casement (side hinge/in-swung type) or SIX TIMES that of their hopper (bottom hing/top in) windows. I ended up using awning (top hing/bottom out) windows at 1/8 the price. I replaced ALL of my house’s windows, the five tilt-turn of 53 windows were almost half the quote. Other American tilt-turn manufacturers either don’t ship to where I live (3) or don’t offer them as aluminum clad wood windows (2), or only extruded vinyl (1). I checked with European manufacturers, but they only send container quantities. I found articles about, references to, and a local builder who had used one American exception (tilt-turn, high quality, small quantity), but they went out of business a few years ago; don’t remember if it was during COVID or the housing crisis. Link to comment Share on other sites More sharing options...
