dskogg Posted June 6, 2017 Share Posted June 6, 2017 Is there a setting ca uses to determine how far to pull cabinet doors and drawers away from another intersecting perpendicular cabinet? I looked around and could not find it and there is no way to change as far as i could see it was locked. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 6, 2017 Share Posted June 6, 2017 Unless it's just a quick concept drawing I don't trust or use Chief's automated blind corners. I make those myself using the cabinet settings. That way you can set the box size and separation to exactly what you want and it won't jump around on you either. Link to comment Share on other sites More sharing options...
MarkMc Posted June 6, 2017 Share Posted June 6, 2017 What Michael said- I keep some standards in the library but often just make em on the fly-split vertical-blank area-ez. Link to comment Share on other sites More sharing options...
dskogg Posted June 6, 2017 Author Share Posted June 6, 2017 So i just need to turn off automatic blind corners then? Link to comment Share on other sites More sharing options...
dskogg Posted June 6, 2017 Author Share Posted June 6, 2017 only problem is when i turn this off there is still no way to change the door width size? Link to comment Share on other sites More sharing options...
dskogg Posted June 6, 2017 Author Share Posted June 6, 2017 Thanks Eric, then i suppose i would need to add my flush door fillers in manually. Link to comment Share on other sites More sharing options...
MarkMc Posted June 6, 2017 Share Posted June 6, 2017 Here are two ways to add filler overlay directly to the cabinet- depends on how fussy you want to be with detail. Since I most often need the overlay as a line item in the schedule I add it manually. Just happens I was working on a blind with an extra door panel and was getting fussy-hence the one to the right. That is the sort of thing I will keep in the library to avoid doing over. The "door symbol" used on the one on the right is placed on the floor- worth opening that to see how it works. Blind.plan Link to comment Share on other sites More sharing options...
MarkMc Posted June 6, 2017 Share Posted June 6, 2017 1 hour ago, dskogg said: then i suppose i would need to add my flush door fillers in manually. Here is update with fillers done similar to how you were looking for the last batch. Note the reason to take the trouble to make the ones on the right side of each pair shows with the doors off or open. Blind 2.plan Link to comment Share on other sites More sharing options...
