HiswayDesign Posted July 4, 2014 Share Posted July 4, 2014 I have not used an eyebrow over an entrance in a while and I have forgotten how to make it happen automatically. I can do it manually but I would prefer to use the automatic feaure. I have CA 10.8 and I can not find any mention in the help file. Can someone give me some guidance? Thanks Link to comment Share on other sites More sharing options...
lbuttery Posted July 4, 2014 Share Posted July 4, 2014 Hmmm, ver 10.8 is not used by many on this forum anymore but you might get lucky ??? you may need to post the plan but if someone works on it with a later version you won't be able to open it good luck Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted July 4, 2014 Share Posted July 4, 2014 it's a type of Dormer ...so place the Auto Dormer , then change the default style to Eyebrow and set the width and height as needed. M. Link to comment Share on other sites More sharing options...
Farrell Posted July 4, 2014 Share Posted July 4, 2014 I think if you select the door (or window) one of the options on the bottom of your screen will be to add a gable over it. Not sure that's what you wanted? Link to comment Share on other sites More sharing options...
