johnny Posted June 1, 2017 Share Posted June 1, 2017 When you export and import layersets are there any quasi-extraneous rules that would effect doing this between x7 and x9? I try an export and then import and nothing shows up in the x9 file - tried 5 times. Link to comment Share on other sites More sharing options...
ShaneK Posted June 1, 2017 Share Posted June 1, 2017 I imported from 18 to 19 with and it was a "wiz bang". Did you reboot? 1 Link to comment Share on other sites More sharing options...
Dermot Posted June 1, 2017 Share Posted June 1, 2017 I have not heard of any problems with this tool. I just tried it and it works fine for me. Did you select all of the layer sets that you want to import? When you get the Import Layer Sets dialog box, you need to either shift-click or control-click all of the layer sets that you want to import otherwise you will probably only import the currently selected one. If this is still not working for you then you probably need to contact tech support for more help. They will need more info from you describing exactly what steps you are doing and what windows you have open at the time you are doing it. Link to comment Share on other sites More sharing options...
johnny Posted June 1, 2017 Author Share Posted June 1, 2017 36 minutes ago, ShaneK said: I imported from 18 to 19 with and it was a "wiz bang". Did you reboot? Yep, that was i guess the issue - i needed to reboot Chief and then they showed up. Link to comment Share on other sites More sharing options...
