Sign in to follow this
MarkMc
Easier way to get millwork into cabinet schedule and symbol hacking
Found this by accident. I'd been going through hoops to get millwork into the cabinet schedule. Arch blocks don't always read dimensions properly, converting millwork to a cabinet door is a pain to place in plan. So
Open new plan, place object, take 3d view with everything else turned off, export as .DAE. Then import as symbol, select type "cabinet", set materials to -plan, use default.
There is an option to select the type of cabinet-base, wall or tall. If you select base and your default cabinet is set to have a counter you will need to change that in the object once you place it.
Once in the library there is very little you can do with the new "cabinet" object.
NOTE-if you're hood has molding that protrudes from the side and you include that with the new symbol the dimension will include the molding as part of the overall size. That doesn't match most brands sizing. Solution is to make the symbol without the molding and add it later. If you are making the hood symbol from scratch that is easy enough.
IF you are using an existing symbol you can hack out the molding and corbels. I've used this technique to hack other library symbols to something else (say you need to alter the top section of a turned leg, ..door symbols were done using this along with a solid and a cabinet.) The easiest way to get rid of those is to hack the symbol through a couple of generations. Plan attached starts with a hood from the library on the left, then shows generations going to the right. Each generation MUST be converted to a new symbol before altering it to the next generation. Look at the stretch planes to get an idea how this works. The last 3 symbols are the new cabinet. The first one is raw, second one I quickly stuck on some molding, 3rd one I add a flat to clean up lines if using a shorter molding than it started with. (this is also useful if there is a hood in the library but you need to change the molding-
Hood to cabinet schedule.plan
You can also address this problem by just changing the bounding box dimensions.
tried that first, does not work on the cabinets I tried
Okay, I see why now.  That doesn't work when you import as a parametric object like a cabinet.  I was just thinking of normal symbols.
Good tips by the way.  I've been meaning to make an advanced symbol modification video myself going over some of these things but haven't found the time just yet.  As you seem to well understand there is A LOT that can be done to modify existing symbols especially when harnessing the power of stretch planes/zones along with delete surface and multiple generations.  Good stuff.
Right, and at this time you can't simply convert a 3D view to a cabinet, the only way is to export and import.
Yep.  Actually, its the ONLY one of the options not available during the normal Convert To Symbol process.  Seems silly.
Yes, but when you consider the complexity of cabinets (doors, drawers, etc) you might understand why CA didn't make it simple.  Back in v9.5 & 10 the ability to convert a 3D view to a symbol didn't exist.  You had to export and import all symbols.
I'm not sure what version of Chief we got direct conversion - but I remember that it was a suggestion that I had made.
I'm not happy this works. A cabinet made this way doesn't allow changing or adding doors or drawers. It would not work as easily IF it did or followed all the defaults.
I agree.  I have tried in the past to make a custom cabinet symbol with doors and drawers using "3D Faces".  It's almost impossible.  However, CA has greatly improved the customization of cabinets so I don't think I would ever try to do a custom cabinet symbol again.
I meant to say I'm JUST happy this works. :wub:
It's kind of cool if you want to put a glass top on a sculpture of some sort.  ;)
You just import your symbol as a Cabinet and specify the counter top as glass.
    27499
    Bren0625
    Bren0625
  • Similar Content
    • By MichaelaS
      Looking for a way to add window and door toppers for interior millwork.
    • By grizzdj
      Hello Friends- I am working on a distillery plan and was wondering if there was a catalog or CA source for distillery symbols like stills, fermenters, mashtuns, chillers, etc.
      Thank You In Advance
      Dan Johnson
    • By PrimeArch
      Hello guys. I made a custom symbols and model for my electrical because CA dont have it.
      I managed to make it but the problem is  they cannot stay side by side.. they will merge  like this
      Btw the can stay side by side if each of em not the same height
      How do i solve this? Please help
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      CLOUD SYNC MULTIPLE USER LIBRARIES FOR MULTIPLE DEVICES/END USERS       DIRECT LINK TO VIDEO X64 SHELL EXTENSION  X32 SHELL EXTENSION PAYPAL THE GUY THAT WROTE THE EXTENSION  ADVANCED LIBRARY SEARCHES DIRECT LINK TO VIDEO       INTRO TO ADVANCED PBR METHODS DIRECT LINK TO VIDEO CREATING ADVANCED MATERIALS IN PHOTOSHOP   DIRECT LINK TO VIDEO AUTUMN LEAVES MATERIAL FILE CREATE A HOTKEY TOUCHPAD USING YOUR ANDROID OR IPAD TABLET     DIRECT LINK TO VIDEO LINK TO SOFTWARE WEBSITE TOUCHOSC METHOD FOR CREATING CON-DOCS IN .PLAN      USING AN IPAD TO REMOTELY CONTROL CA. METHOD OVERVIEW   ADVANCED TOOLBAR CONFIGURATIONS   NEW!!! 08/28/2019
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By LeahPugh
      The callouts for the electrical symbols (threeway, dimmer, timer, etc) do not change scale with the electrical labels. I am working in 1/4" scale and the symbols are tiny. I am receiving complaints from my builder that they cant read the symbols.  Is there a way to change the size on the symbols?
