hobgood Posted May 20, 2017 Share Posted May 20, 2017 Need Help Chief V9 Working on a new plan only 2828KB at this time (garage add to an existing Manufactured home) When I change from the floor plan to the Overview or back clipped section view it take longer as I work more on the plan it will take minutes to change and eventually locks up. I did not have this issue with Chief V8 HP Envy intel I7-4770 @3.40 GHZ 64 bit windows 10 32 GB ram GeForce GT640/PCI Open GL shows 3.3.0 with 4095 GB video memory Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 20, 2017 Share Posted May 20, 2017 Please post a copy of the problem .plan file so others can evaluate its performance on their machines. There are too many possible variables to guess at just from your post above. DJP Link to comment Share on other sites More sharing options...
hobgood Posted May 20, 2017 Author Share Posted May 20, 2017 I have attached 2 files, both with the same issue Only 2 I have tried in X9 Thanks 8621 Hume Lever Rd.plan Peggy Lane Ranch.plan Link to comment Share on other sites More sharing options...
hobgood Posted May 20, 2017 Author Share Posted May 20, 2017 I just tried it again, first try from floor plan to overview and back Message serious error SEH contact technical support I have received this message several time in x9 but not in x8 Link to comment Share on other sites More sharing options...
hobgood Posted May 21, 2017 Author Share Posted May 21, 2017 It appears to be not properly changing views I have floor plan open, cross section open full overview and elevation cross section When I go to the window button and hit floor plan it may come up with the section or one of the other views open It seems to go where it wants ?????? I updated the mouse driver Logitech m215 Any thoughts Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 21, 2017 Share Posted May 21, 2017 I tried both of your plans, got no error messages and found both plans to be rather ordinary in performance in X9. I can only assume that the problem lies in your own PC hardware and or software other than Chief. Probably not what you wanted to hear but all I can report is what happened or failed to happen. DJP Link to comment Share on other sites More sharing options...
Dermot Posted May 21, 2017 Share Posted May 21, 2017 This is mostly likely the result of video card or driver issues. See this tech article regarding these kind of issues: https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems.html If this does not help you solve your problems, then you should contact technical support on Monday. Link to comment Share on other sites More sharing options...
