Sign in to follow this
hobgood
X9 slow from floor plan to overview and backclipped section
Need Help  Chief V9 Working on a new plan only 2828KB at this time (garage add to an existing Manufactured home)
When I change from the floor plan to the Overview or back clipped section view it take longer as I work more on the plan
it will take minutes to change and eventually locks up. I did not have this issue with Chief V8
HP Envy intel I7-4770 @3.40 GHZ
64 bit windows 10
32 GB ram
GeForce GT640/PCI
Open GL shows 3.3.0 with 4095 GB video memory
Please post a copy of the problem .plan file so others can evaluate its performance on their machines. There are too many possible variables to guess at just from your post above.
I just tried it again, first try from floor plan to overview and back
Message serious error SEH contact technical support
I have received this message several time in x9 but not in x8
It appears to be not properly changing views
I have floor plan open, cross section open full overview and elevation cross section
When I go to the window button and hit floor plan it may come up with the section or one of the other views open
It seems to go where it wants ??????
I updated the mouse driver Logitech m215
Any thoughts  Thanks
I tried both of your plans, got no error messages and found both plans to be rather ordinary in performance in X9. I can only assume that the problem lies in your own PC hardware and or software other than Chief. Probably not what you wanted to hear but all I can report is what happened or failed to happen.
    28296
    MarenM
    MarenM
