LOVdandd Posted May 18, 2017 Share Posted May 18, 2017 Maybe this has already been addressed but, can someone explain why my deck structure keeps disappearing. I have attached picture to explain. I can draw a stand alone deck and it looks great. The minute I attach it to a building, it drops my the decks. Labels, area, railings all there but no structure. What am I doing wrong, or is there a setting I need to change? Thank you in advance, Nestor Link to comment Share on other sites More sharing options...
Chopsaw Posted May 18, 2017 Share Posted May 18, 2017 That will happen when you loose room definition. You need to make sure you have a positive connection to the building to form the room with a forth wall shared with the house. If you are having difficulties and it is not that simple you can always post your plan file and someone will usually take a look for you. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 19, 2017 Share Posted May 19, 2017 Just check this box Link to comment Share on other sites More sharing options...
