How to calculate Material quanitities (area)
CBuserIndia
Hello Friends
I am using Chief Architect Interior X9.
I have few questions regarding material quantity, is there any CA options that can easily give below quantity numbers.
1) How do I calculate sqaure feet (area) of plywood/wood used in a furniture ?
2) I want to calculate wall area that needs to be painted, How do I calculate area of wall inside a room ?
3) If I have applied wallpaper/wall covering on certain wall, how do I calculate square feet (quantity) of wallpaper used ?
Instead of manually calculating areas of such items, is it possible to get them in button click. When you design you select & give dimension to these materials, so CA has all this information. How do I get these numbers out ? It doesn't make sense to calculate them manually.
Please suggest
Thanks
Nitin
