Gary_Swanson Posted May 13, 2017 Share Posted May 13, 2017 I need to draw a structure made of steel I-beams and columns like in the pic. I have never used steel before and I'm having trouble figuring this out. Is there a video I should look at or could someone tell me the basic's of what to do to use steel components. I need to be able to use steel for the rafters and set a pitch. Any help at all would be appreciated. Link to comment Share on other sites More sharing options...
joey_martin Posted May 13, 2017 Share Posted May 13, 2017 Change the 2"X lumber in the roof defaults to Steel-I and set the distance. The purlins will need to be added manually. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 18, 2017 Share Posted May 18, 2017 There is also Steel Beams in the Library if you have SSA https://3dlibrary.chiefarchitect.com/index.php?r=site/library&category=Specialty%2FOther%2FMisc Link to comment Share on other sites More sharing options...
