BlackDiamond Posted March 24, 2017 Share Posted March 24, 2017 Hi.... I need to create a Flooring Set that shows each rooms flooring graphically. I want to be able to have it show for the 'Flooring Set' but not on my dimensioned/noted floor plan set. How do I do that? Basically I need the hatch pattern to be on a separate layer that I can turn on and off. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 24, 2017 Share Posted March 24, 2017 Is this the same question as: Or are you looking for something a little different? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 24, 2017 Share Posted March 24, 2017 You can use Floor Material Regions. They are by default on the "Material Region" layer but can be moved to other layers if needed. Link to comment Share on other sites More sharing options...
BlackDiamond Posted March 24, 2017 Author Share Posted March 24, 2017 Thank you!!! Worked perfectly! Link to comment Share on other sites More sharing options...
