Double Vision Elevation Views
mrscott
While I wait (Since March 3rd) for the developers to correct their programming errors, please check this video let me know what you think might be happening and how I can correct it without removing all the features Chief is advertising. If you need the plan and Layout I can upload them separately  as they are 27MB in one zip.
Thanks again for all your help!
Scott that is an old X8 problem showing up again that was supposedly fixed a long time ago.  If you are sure that you do not have a duplicate layout box then there is a major offset issue with Plot lines and color fill again the same as in X8.
Chop,
Thanks for the followup. I double checked the Layout box and there is only one VIEW there. I was pretty sure because I just updated view to my revised layout template. So, I guess it is a carryover from X8. Are you able to reproduce it on you side?
