Reduced Pork Chop (Boxed Eave)
Sweeney
Hey all,
Was there ever a preferred technique found to accomplish the "Reduced Pork Chop" look? (see attached picture)  I have read that two roof planes does the trick, but I can't seem to figure out how to make the wall look appropriate where the soffit transfers from sloped to flat. Do you use a polysolid to fill in the space? Whats the secret?!
Has someone made a video on this that I can't seem to find?
Thanks
Austin
Yes that is correct, you see this style roof return often in New England. Chief offers either a boxed eave return or a sloped soffit. I am trying to use a flat soffit under the eave of the roof (which is acquired with a "boxed eave" checked) and a sloped soffit on the roof rake (with is acquired with "boxed eave" unchecked). Attached is another photo.
Solver,
Exactly, however I can't seem to make that work via. options/flush eave in X9.
Edited by 2wheeltodd
Actually it worked perfectly on a different plan. VERY much appreciated Solver! +1 for you.
