Austins Posted March 1, 2017 Share Posted March 1, 2017 I've been spending hours trying to make a simple demo plan with dashes for the walls etc to be removed. I got it to the point where I was able to create a CAD Block full of dashes that I thought I could copy and paste hold back to the original plan and then when I remove a wall etc. the underlying AS-built wall would show dashed as in the underlying mask. When I take the CAD Block below which is dashed and copy hold it into the plan it comes out with solid lines not dashed! Very frustrating. Why ishn't it copying the dashed lines that are in the CAD block? thanks in advance for any help. Link to comment Share on other sites More sharing options...
dshall Posted March 1, 2017 Share Posted March 1, 2017 Just now, Austins said: I've been spending hours trying to make a simple demo plan with dashes for the walls etc to be removed. I got it to the point where I was able to create a CAD Block full of dashes that I thought I could copy and paste hold back to the original plan and then when I remove a wall etc. the underlying AS-built wall would show dashed as in the underlying mask. When I take the CAD Block below which is dashed and copy hold it into the plan it comes out with solid lines not dashed! Very frustrating. Why ishn't it copying the dashed lines that are in the CAD block? thanks in advance for any help. Try watching this vid Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 2, 2017 Share Posted March 2, 2017 Anything I want to show dotted like cab. and toilets, or just anything in the plan, I just make sure its turned on when I send it to ,"View to cad" ,and its all converted, then just put it all on 1 layer and lock it. Link to comment Share on other sites More sharing options...
