SNestor Posted February 21, 2017 Share Posted February 21, 2017 How do you use these garage door panels? They are individual panels...do you have to use them to create a new door "door symbol"? When you select one to be the garage door...it becomes one single "distorted" panel...not a multi-panel as you would suspect it would. - Is there a simple raised panel garage door in the library? I can't seem to find one. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 21, 2017 Share Posted February 21, 2017 Steve, Set the # of panels in the Garage Door dbx 1 Link to comment Share on other sites More sharing options...
SNestor Posted February 21, 2017 Author Share Posted February 21, 2017 Never mind...I figured it out. I had placed a door from the "coachman Collection"...and then I tried to replace the door using the "door dbx"...clicking "library". Well...that does not work. In order to use the panels as a garage door...just click on the panel you want and place the door into the wall. Voila! Works as designed.... Link to comment Share on other sites More sharing options...
SNestor Posted February 21, 2017 Author Share Posted February 21, 2017 1 minute ago, Joe_Carrick said: Steve, Set the # of panels in the Garage Door dbx Thanks Joe...I had not seen that menu item. Appreciate the help! Link to comment Share on other sites More sharing options...
