Question on exterior wall layers
foxbody89
My exterior walls consist of cmu block with an insulation board layer and a furring strip layer with a finished drywall layer.  For some reason my insulation layer is peeking through the drywall on my 3d views and I have no idea why this is happening, is there a way to make this hidden like it should be?  I attached a picture of what I am talking about.
2 minutes ago, javatom said:
It looks more like a plan problem than a wall definition problem.  It could be an intersecting floor platform.  Maybe you could post the plan.
It acts like a glitch to me because sometimes it shows the furring strip material instead of the insulation
Ignore my suggestion about the framing material - I just dug into my own wall definitions and discovered I've defined my interior furring as framing also, and I don't experience any issues.
Is the room shown in a basement? What's happening on the other side of the wall? Why don't you post the plan so we can take a closer look.
