capitaldesigns Posted February 2, 2017 Share Posted February 2, 2017 I have a sliding barn style door in one of my projects. Its not a pocket door but it does slide on a rail attached to the side of the wall. I used the doorway command to create the opening. I manually drew the door in the open position since I could not find a similar door in CA. How do I get this door to show up in the door schedule ? Is there a way to add an extra line in the door schedule so I can manually type it in ? Thanks, Mike Link to comment Share on other sites More sharing options...
Chopsaw Posted February 2, 2017 Share Posted February 2, 2017 Mike, The last one I did I also tried to use a doorway and could not make it work. Resorted to a hinged slab door and changed most of the vizible materials to "Opening (no material)" and then edited the Description Column to say "Doorway For (size) Sliding Barn Door". Then I just needed one tiny cad line mask over the slab door in plan view. I put in a request to tech support at the time for it to work with a doorway, quite logical. Chopsaw Link to comment Share on other sites More sharing options...
rlackore Posted February 2, 2017 Share Posted February 2, 2017 When I have to add a custom door to the schedule, I create a "Doors, Hidden" layer, draw a wall off to the side of my plan, then insert a hinged door and edit the Components so the schedule reads correctly. I've found this a useful method for shoji screens, barn doors, over-head coil doors, etc. 3 Link to comment Share on other sites More sharing options...
BKEn10c Posted February 3, 2017 Share Posted February 3, 2017 16 hours ago, rlackore said: When I have to add a custom door to the schedule, I create a "Doors, Hidden" layer, draw a wall off to the side of my plan, then insert a hinged door and edit the Components so the schedule reads correctly. I've found this a useful method for shoji screens, barn doors, over-head coil doors, etc. Great work-around. Maybe CA will give us barn doors? They are becoming increasingly popular. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 3, 2017 Share Posted February 3, 2017 8 minutes ago, BKEn10c said: Maybe CA will give us barn doors? They are becoming increasingly popular. https://3dlibrary.chiefarchitect.com/index.php?r=site/detail/895 Link to comment Share on other sites More sharing options...
BKEn10c Posted February 3, 2017 Share Posted February 3, 2017 8 hours ago, Chopsaw said: https://3dlibrary.chiefarchitect.com/index.php?r=site/detail/895 Thanks Chopsaw - good to know that is there. I have a project coming up where I need one. Link to comment Share on other sites More sharing options...
