Joe_Carrick 2326 Posted February 1, 2017 Video of the EASIEST TO USE Site Area Analysis Package. This macro package includes a Layer Set and an Annoset plus all the macros needed. 2 Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 1, 2017 Nice Joe, it covers everything you might need, can't wait. Share this post Link to post Share on other sites
dshall 1502 Posted February 1, 2017 What Joe has done is super. Something I have been asking CA to do since 1973. Michael takes a different approach and to date I am using his approach. When I choose a method to use, all I care about is which method is the easiest for me to implement into my plans. I want a method that I can customize. Joe, I think it would be beneficial for anyone considering using your program if you can illustrate how easy it would be to modify the formulas. I am talking about adding up the existing areas and getting a total, adding the new areas and getting a total, adding new areas and existing areas together and dividing by the lot area to get the FAR. And adding the first floor areas and dividing by lot area to get the coverage. Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 1, 2017 3 hours ago, dshall said: Joe, I think it would be beneficial for anyone considering using your program if you can illustrate how easy it would be to modify the formulas. I am talking about adding up the existing areas and getting a total, adding the new areas and getting a total, adding new areas and existing areas together and dividing by the lot area to get the FAR. And adding the first floor areas and dividing by lot area to get the coverage. Scott, Most of what you ask for is already in the package. Property Area Buildable Area .....(inside Setbacks) Setback Area .......(Property-Buildable) Habitable Area .....(Total of all Floors) Lot Coverage .......(Total named 1ST FLR + Garages)/Property FAR ......................(Habitable/Property) ---- additional areas can be added to the FAR calc. Impermeable ........(Total named 1ST FLR + Garages + Driveways + Walks + Decks + Porches + Slabs, etc.) There are only a 4-5 macros that might need additional named areas added (1 line per macro) and that's only if you use layer names that don't follow my predefined format. You might want to watch the video again to see what's included. Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 1, 2017 Is it ready for prime time now? Share this post Link to post Share on other sites
dshall 1502 Posted February 1, 2017 20 minutes ago, Joe_Carrick said: Scott, Most of what you ask for is already in the package. Property Area Buildable Area .....(inside Setbacks) Setback Area .......(Property-Buildable) Habitable Area .....(Total of all Floors) Lot Coverage .......(Total named 1ST FLR + Garages)/Property FAR ......................(Habitable/Property) ---- additional areas can be added to the FAR calc. Impermeable ........(Total named 1ST FLR + Garages + Driveways + Walks + Decks + Porches + Slabs, etc.) There are only a 4-5 macros that might need additional named areas added (1 line per macro) and that's only if you use layer names that don't follow my predefined format. You might want to watch the video again to see what's included. Joe, I do not need to watch it again. I saw it. I was sharing what I would of wanted to see to determine whether the macro would work for me. Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 1, 2017 Scott, I don't understand what you are asking for that I didn't show in the video. All of those calculations were shown and there's nothing you need to change in the macros. 1 Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 1, 2017 I think Scott is looking for a video on how to add a new area in case you didn't have it in your list. Maybe Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 1, 2017 27 minutes ago, DRAWZILLA said: Is it ready for prime time now? Yes, I just need to export the Layer Set and Annoset and add a short set of instructions. I'll send it to you tonight. Share this post Link to post Share on other sites
dshall 1502 Posted February 1, 2017 1 minute ago, Joe_Carrick said: Scott, I don't understand what you are asking for that I didn't show in the video. All of those calculations were shown. I suppose I was looking for an example of how you might add a new area and how you might add a different macro/calculation. I was hoping to observe how quickly it could be done. As I stated before..... "Joe, I think it would be beneficial for anyone considering using your program if you can illustrate how easy it would be to modify the formulas. I am talking about adding up the existing areas and getting a total, adding the new areas and getting a total, adding new areas and existing areas together and dividing by the lot area to get the FAR. And adding the first floor areas and dividing by lot area to get the coverage." Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 1, 2017 4 minutes ago, Joe_Carrick said: Yes, I just need to export the Layer Set and Annoset and add a short set of instructions. I'll send it to you tonight. Thanks Joe, I will be adding it to my template plan, and probably just copying it to the plan Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 1, 2017 (edited) Adding a new area is simple: Create a new Polyline Edit the layer to one of the predefined layers Add the macro %Areas% to the Polyline Label. The macros in the RTB will automatically respond according to the Layer Name. Property LineStyles and Setback LineStyles are recognized for those areas. Layers containing PROPERTY and SETBACK are recognized for those areas - either will work.. Layers containing 1ST FLR, 2ND FLR, 3RD FLR, 4TH FLR or .1 .2 .3 .4 are considered "Habitable" Layers containing GARAGE are naturally considered to be "Garages" and are a part of Lot Coverage Layers containing 1ST FLR or .1 are also considered a part of Lot Coverage. Layers containing DECK, WALK, DRIVEWAY, PORCH or SLAB are considered as "Impermeable" along with the Lot Coverage layers. Permeable is calculated as Property - Impermeable FAR is calculated as Habitable/Property Macros included are: %Areas% ---------- placed in the Label of a Polyline adds the name and area to a Hash Table %Areas Property% %Areas Setback% %Areas Buildable% %Areas, List Habitable% ---- This includes the Total %Areas, List Impermeable% -- This includes the Total %Areas Permeable% ---------- Calculated & Displayed %Areas, List Lot Coverage% - This includes the Total %Areas Lot Coverage% ------- Calculated & Displayed %Areas FAR% ---------------- Calculated & Displayed What did I miss? OH, I know - if you want to use a name that doesn't conform to the above, You just have to add that layer name in one line of the macro (only 5 possible) where you want it to be included in the calculations. Edited February 1, 2017 by Joe_Carrick Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 1, 2017 I should note here that I'm not going to demo editing any of my macros in videos. If I do that I might as well just give them away. A comprehensive system like this one took a lot of time to program and debug. Instructions for how to add layer names - the only thing that needs to be done - is provided with the package. 1 Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 1, 2017 thanks, sounds easy Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 3, 2017 Joe , I have looked at your site analysis package and it works great, very easy to add areas, without having to mess around with the macros. Good job. it's a lot easier to add layers rather than trying to adjust the macro, but you also make it easy to do that too. Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 3, 2017 Thanks Perry, My approach is to provide functionality that doesn't require anyone to be a programmer. I try to do that with all my macros, basically trying to make them "Turn Key". It's enough for users to learn Chief, without them needing to learn to program scripts in Ruby. Now if I can just get some paying customers. ps: I'm going to get a new USB WiFi for my home computer. The one I have is older technology and just doesn't have enough speed and bandwidth. Then I'll be able to create and upload videos much easier. The last one took about a half hour to upload. Share this post Link to post Share on other sites
DRAWZILLA 780 Posted February 3, 2017 Joe, right now I have 350mbs going on, and hardwired, of course I pay extra for that. Share this post Link to post Share on other sites
Joe_Carrick 2326 Posted February 3, 2017 I just checked and my Cox Wireless Modem is only 2.4 GHZ (802.11n) which matches my USB WiFi. I think I'm going to need to upgrade both - or hard-wire between the router and my computer. Unfortunately running the wire isn't going to be easy due to the location of the computer. But that would obviously be the best solution. Share this post Link to post Share on other sites
