fangelo Posted January 31, 2017 Share Posted January 31, 2017 Does anyone know why this is happening? The scale on dimensions jumps all out of whack on the layout sheet (see Capture 1) I can temporarily fix the layout sheet by opening one of the linked details and then closing it...all of the linked details then update and look ok on the layout page ( see Capture 2). This keeps happening on this layout page only. Any Ideas? It's driving me nuts. This is in X9 by the way. Thanks, Fred Link to comment Share on other sites More sharing options...
Richard_Morrison Posted January 31, 2017 Share Posted January 31, 2017 Probably better report it to tech support. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 1, 2017 Share Posted February 1, 2017 Now that you bring this up, I remember that I had angular dimensions do that to me once before as well. It showed up for a very short period on a plan I was using to make a quick tutorial video and then never showed up again. I'll often just start a new plan between takes if I screw something up and I'm pretty sure I just started a new plan and all was well. Anyway, the problem showed up and disappeared so quickly that it didn't really cause me any notable problems and so I guess I figured it was some kind of fluke and I never reported it. Richard is right though. It should prolee be reported. Link to comment Share on other sites More sharing options...
rlackore Posted February 1, 2017 Share Posted February 1, 2017 Happens to me all the time with angular dimensions. Sometimes the problem shows up in plan, other times in layout, other times not until I print. Very frustrating. I've quit using angular dimensions; now I draw an arc, put arrows on the end, and use text to call out the angle. Link to comment Share on other sites More sharing options...
