C2Claire 1 Posted January 23, 2017 Why can't I place a cabinet in a doorway? I understand that typically you wouldn't do that with a standard doorway (36" wide) but we often open up walls from 1 room to another that are 8-9 feet wide. Working on a project right now that I can't figure out how this should be done or will the software just not let me do it? Do I not specify it as a doorway but a different type of wall? Should I just do a short interior wall on either end instead? I think I tried that before on another project but gave up and the design changed to not include the need for it. I've been working with Chief Architect only 6 months, so maybe I'm missing something obvious? 1 Share this post Link to post Share on other sites
MarkMc 532 Posted January 23, 2017 Use point to point move OR transform replicate to place accurately into a doorway or opening. You can override bumping by holding down the control key but it lacks accuracy. Share this post Link to post Share on other sites
C2Claire 1 Posted January 24, 2017 Thank you! That worked! Share this post Link to post Share on other sites
lizdion 3 Posted August 3, 2017 I was having this problem and this is the only thread I found about it. The cabinet runs perpendicular to the wall opening and the end disappears on the plan no matter how I place it. On 3d the cabinet shows but countertop is missing. Add a custom top and both plan and 3d look correct. Liz 1 Share this post Link to post Share on other sites
dshall 1493 Posted August 4, 2017 23 hours ago, lizdion said: I was having this problem and this is the only thread I found about it. The cabinet runs perpendicular to the wall opening and the end disappears on the plan no matter how I place it. On 3d the cabinet shows but countertop is missing. Add a custom top and both plan and 3d look correct. Liz Very frustrating..... I should be able to have a cabinet go through a doorway. Two pics, one showing it does not work, the other pic showing it will work..... to make it work,. cut out offending wall, and then paste back in original position..... 1 Share this post Link to post Share on other sites
lizdion 3 Posted August 4, 2017 It works for the cabinet in the 3d but the countertop is lost. I put a custom counter over it and that made it work in plan and 3d. Seems like we could do it without a workaround a few versions ago. Liz Share this post Link to post Share on other sites
