brian-sdesign 5 Posted January 3, 2017 I've been working on getting my start up template dialed in. I used it to start a new project today and am getting some unexpected results. Some of my interior walls are showing exterior siding as a surface material. When I open the wall dbx, and look under wall types the materials are set to drywall but the preview shows it as siding as well. Somehow it's getting overridden. Can anyone shed some light on this? Share this post Link to post Share on other sites
MPDesign 29 Posted January 3, 2017 post the plan, my guess is your using an exterior wall or your copy was made incorrectly. Share this post Link to post Share on other sites
brian-sdesign 5 Posted January 3, 2017 Okay, I'll post it shortly. I did check that though Share this post Link to post Share on other sites
brian-sdesign 5 Posted January 3, 2017 It's something to do with rooms I believe. In some cases I'll have part of a wall showing siding and part of it drywall where another room starts. The room types were the same though. Very frustrating Share this post Link to post Share on other sites
MPDesign 29 Posted January 3, 2017 Brian, Maybe it is the direction you are drawing your walls? Are you using the same wall selection handle? the small diamond on the end Share this post Link to post Share on other sites
rlackore 407 Posted January 3, 2017 Select the problem rooms, open the Room Specification dbx, and make sure the Materials>Room>Walls is set to use the Default material: Share this post Link to post Share on other sites
