Small 24 x 36 house slab on grade, 24" crawlspace
Clemsongrad
This house has changed sizes 6 times and I'm wondering if I should just draw it all over.
I'm not sure how to create the house with a slab on grade with a center thickened slab with 24 " crawlspace (3 concrete block high) then conventional floor rafters (or possibly floor trusses)
When I drew the slab as a stand alone drawing I got some funny conditions even after a bunch of you jumped in to help.
See attached
24x36 Slab rev3.plan
Let me try to understand:  You drew a plan and have changed it 6 times.  You want a slab on grade and then build a stem wall with floor joist.
Draw the house walls first then build foundation (stem wall).  Add slab later.
Normally you would:
Build your crawl space walls on level 1 and your main floor walls on level 2.
Auto build a mono slab foundation.
In your case:
Build Floor...Build Foundation with mono slab.
You will now have a mono slab on level 0, a crawl space with wall on level 1.
Now build level 2.
You will need to fix things like floor/ceiling heights and structure types as well as wall definitions.
There are any number of ways to get where you want, but the above is a basic outline.
Let me know if you want to do a Skype session and I will run you through it.
